By LCP92
Guys, I've got a 1999 Honda Foreman 450S. It runs great, but smokes out the exhaust after startup until it warms up. I'm thinking the valve seals are leaking. I was wondering if there is a way to replace them without removing the head or if there's an oil additive that will recondition the rubber seals. Any advice?
By BillR94
Thank you for your time
Bill
By DexKing
I recently got my hands on a free 2004 Recon that the owner had zero information on the machine or the history. Long story short, a little troubleshooting and research revealed i needed to replace the timing chain for it to stay running. when i opened the case, it the chain was so horribly stretched, that the tensioner pivot arm had play between it and the chain! I also found the oil pump chain totally disconnected from the sprocket due to being completely worn out. I tore the whole engine down and rebuilt it from the bottom up finding little things here and there that needed to be replaced. Upon inspecting the top end, i didn't find any bad/excessive play in the crank, rod bearings or wrist pin. Now the machine runs great, but even after 2x adjusting the valves, the chatter is way more than you'd expect from a honda normally. My neighbor is an auto mechanic by trade, and i asked him to take a listen. the look on his face when i started it and it was chattering like that was priceless! He mentioned that maybe the valves themselves might be wore out or stretched. my question here: what all can cause the excessive rattle up in the valve cover aside from valves being out of spec? Everything else seemed to be in decent condition as far as rockers and guides go. I am fairly new to small engine/ATV repairs, but am learning as a hobby and have a fair amount of knowledge with how to do some wrenching. Thanks!
By Louznmemind
I know this is a stupid question but here I am.. I'm wanting to have the ability to disable my taillight/brake light on my '96 Polaris Xpress at will, it comes on with the key and there are times I don't want it to illuminate. I have basic wiring knowledge and I'd like to put a toggle switch to disable it. I'm not sure of the wiring setup on this thing, can I just use a toggle switch on the ground wire to kill it when I choose? Can someone clarify which wire I need to work with and the easiest way? Excuse my ignorance yall.
By Kurt Reiser
My quad will not run with the airbox hooked up Will not go past quarter throttle as soon as you unhook the tube at the back of the carburetor it runs great does anybody have any ideas what it could be I have a bad fuel pump one on the way can that cause the quad to run like that
