  • 4 months later...
    • By marcosphoto
      Hi folks, a little disparity brought me to this forum.  To set the stage, I'm a 35 auto tech in the industry 37 years now.  Licensed motorcycle tech also, 20+ years.  I race superbike and motocross.  Always done most of my own standard work (outside of specific race machine works) including building my own race bike engines.  Now that skills are out of the way, onwards and upwards.
      Helping a neighbor with his old quest 500, right front axle seal leak.  Well, looks like everything else - right?  Wrong!  Initially I noticed the CV joint was lacking large lands to place prybars on to pop it out, rather a thin shield like ring very close to the diff seal.  Knowing the ring appeared quite delicate, I only pried gently and the CV popped out.  However this is where things get weird.  Came out only around 7-9mm then hung up again, felt like the clip was catching inside the diff.  So spun and pulled, spun and pulled until I was blue in the face but no success getting it out.  Also while it was out, I could see that the delicate ring around the outer circumference of the joint was actually the sealing surface where the seal contacts, instead of the norm where the seal rubs inside the diff much deeper and stays cleaner.  I've never seen a joint like this, also the service manuals photos which apply to 650 also reflected a standard joint I am accustomed to rather than this one I was fighting with.  Rather than break something in the diff, I decided to stop while I was ahead and reassemble the machine before something broke.  (The joint would pop in and out of place easy enough, just wouldn't slide out further than 7-9mm).  While the joint was a little out and sealing surface exposed, I cleaned the seal and sealing surfaces clean as possible before putting back together.  Seems to be holding for now, but eventually I'm sure the leak will come back.  Any thoughts as to why that CV joint just refused to come all the way out?
    • By Jhb12686
      Hello I appreciate the welcome into the group. I am beyond frustrated with this desperate search for parts. I have a 2013 XY power sports UTV 300. I had a catastrophic failure in my rear differential which resulted in the destruction of almost everything inside. I have located everything I need to completely redo the rear end. But I cannot find a short side axle shaft with six splines etc. it's an offset differential and one shaft is longer than the other and I need the short one. The tip of it broke off (pic). Any help in getting another shaft for this thing would be GREATLY appreciated. Thanks guys
      If you're an outdoor enthusiast looking for adventure and off-road fun, an all-terrain vehicle (ATV) is an excellent choice. ATVs have become increasingly popular over the years, offering power, versatility, and excitement for riders of all skill levels. As we dive into 2023, let's take a look at some of the best ATVs the market has to offer.
      1. Yamaha Grizzly 700
      The Yamaha Grizzly 700 is a top contender in the ATV world. Its powerful 686cc engine delivers excellent performance, whether you're traversing rugged terrains or towing heavy loads. With Yamaha's Ultramatic transmission, the Grizzly 700 offers smooth and seamless gear shifting, making it a joy to ride. Its advanced suspension system ensures superior handling and comfort, while features like electronic power steering and On-Command 4WD add to its versatility.
      2. Polaris Sportsman XP 1000
      The Polaris Sportsman XP 1000 is another top-rated ATV known for its power and performance. Equipped with a 952cc engine, it delivers impressive acceleration and speed, perfect for adrenaline junkies. Its high ground clearance and active descent control provide excellent off-road capabilities, while the electronic power steering ensures easy maneuverability. The Sportsman XP 1000 also offers ample storage space, making it a practical choice for longer adventures.
      3. Can-Am Outlander X mr 1000R
      The Can-Am Outlander X mr 1000R is designed for those who crave extreme off-roading experiences. With a 976cc engine and a specially designed mud-ready transmission, it's built to tackle the toughest terrains. The Outlander X mr 1000R features snorkel air intake and relocate differential breathers to provide exceptional water fording capabilities. Its aggressive mud tires and sturdy suspension ensure maximum traction and durability, making it an ideal choice for off-road enthusiasts.
      4. Honda FourTrax Rancher
      The Honda FourTrax Rancher is a reliable and versatile ATV suitable for a variety of outdoor activities. Powered by a 420cc engine, it offers smooth power delivery and excellent fuel efficiency. Its compact size and lightweight design make it maneuverable in tight trails, while the independent rear suspension provides a comfortable ride. The FourTrax Rancher also features Honda's Electric Shift Program, allowing you to effortlessly change gears with the push of a button.
      As you explore the market for your next ATV adventure, keep these top 2023 models in mind. Whether you prioritize power, versatility, or reliability, these ATVs offer exceptional performance and features to enhance your off-road experiences. Get ready to embrace the thrill of the outdoors and take on new adventures with one of these remarkable machines!
      Do you agree? Comment below
    • By BiminiMike
      Hi.  I am looking to purchase an ATV for a Bahamian island called Bimini.  It is 50 miles from Miami.     I am looking for something that will ride the beaches without getting stuck.   There is lots of shoreline with some mangroves, vegetation.   So will probably need 4x4 for that area.  But I ready somewhere that the  the extra weight of the 4x4 in the front of an ATV will weigh down traveling on teh beach and make it more susceptible to getting stuck?      I would think you'd want 4x4 for beach sand.    I would also like to use this ATV to pull a small trailer for bringing trash to the local dump.     I am considering the Honda 420 4x4 with foot shift (dont want to fix ES on an Island).  I am also considering the Honda Foreman for the pulling capacity but I'm concerned that the extra weight of the Foreman will be prone to getting stuck in beach sand.   Anyone have an opinion?
