I have a 2009 Outlander Max LTD which I swamped a few weeks back. Went through the routine of draining everything and changing the oil & filter until I had everything flushed out and good clean oil.
Now my machine fires up no problem when cold, does not appear to be burning any oil, no active P codes.
After I ride for about an hour and everything is good and warm, when I shut the machine off and go to fire it up again, it turns over really hard like the battery is dead. It will start again after some coaxing. Then I can ride again no problem and it starts fine after I get it loaded, get back to town and unload.
This has me worried that I am going to get stuck out in the woods with a problem machine.
I suspect that maybe I have a scuffed piston or stuck rings? But before I go tearing down the engine and spending a bunch of cash, I was wondering if anyone out there has seen the same type of problem?
to me it sounds like your rod bearings or your main bearings are swelling when they get hot. there could be the possibility of a spun bearing as well. i don't think it is stuck rings or any thing like that. the first thing to do is get it hot then try and pull start it. if it is almost impossible to pull if it even moves at all then your engine is siezing up when hot. i would sure suspect that just by what you explained. good luck.
your friendly neighbourhood mechanic
Thanks for the information...
Ran it up to temperature again this morning and pulled the plugs and was able to roll the engine over by hand, but when I dropped the oil - theres metal filings, so it looks like a tear down & rebuild is next.
I would think that after dunking it, you could have a battery or connection problem somewhere. Metal flakes in the oil would certainly have me looking well past that though. Rotax is one of the only manufacturers that I have ever seen that uses a plain bearing for the crankshaft main and rod bearings in ATV engines. I think that Gearhead may be on to something with the bad or spun bearing theory. If that were the case, you don't want to be riding that thing until you get it fixed. If you were to lose one of those bearings completely, it could be catostrophic.
    • By canamKID
      Anybody familiar with this noise from my quad? Just started.  It temporarily goes away when I attempt to shift into another gear but shifting has gotten harder too.
      20260711_150338.mp4
      Hi everyone, first and foremost, I want to thank everyone for all the help I've received. I am so glad I found this community. I also wanna apologize if I'm spamming the forum, I come up with questions as I go, I guess lol. So when I got my Recon, the air box was missing the lid, held together by zip ties, and the filter was ripped and nasty. I have since ordered a new air box assembly. It comes with everything: the box,  lid, and filter ( the insert and the foam), and all the hardware necessary. This is the first time I've seen a metal filter inside a foam filter lol. However, my question is, I have read that you have to oil these filters? Every time I read it, it was always skimmed over, and I could not remember where I had read it. Is there a certain oil needed for this? Is the filter washable and reusable? Do I just stick the filter in oil, lol? Sorry if it sounds like a dumb question. Thanks in advance, y'all!
    • By prdicon
      Polaris it a bit cheaper.
      Let's say 3-5 years from now.
    • By kevinohio
    • By Coyote251
      I am hooking up a speaker on the rear of bike and want to use a factory auxiliary switched plug and not have to cut into the factory wiring or add another switch. I have read a bunch of posts that say there should be an auxiliary 12V connector in the front and one in the rear. I found the one in the front when I hooked up my winch but cannot find any in the rear. I have seen some pictures showing one on the right side attached to the down tube behind the side cover, but there is nothing on my 2024. Can anyone confirm that there is a auxiliary 12V connector in the rear on the 2024 700 Xmr? If so, can you please tell me where it is (with a picture if possible)?
