Old battery was exchanged when new one was bought. I have proper Voltage at battery. I've also bypassed the starter relay to make sure starter works. Ther has to be something in the ignition circuit. Batt conn is fine so are the relays. Gonna try to bypass key switch and start switch 2morrow.
i did not say to charge the battery. i asked if you tried to charge the old battery while it was in the quad. if you did you might have fried something. you should always disconnect the battery when you are charging, because rhe ecm has a reference voltage that kills the unit when it is charged with something other than an alt or generator. instead of bypassing the switch go down to the starter solenoid and check for power when you turn the key on to the start position. if it lights up your ignition circuit is ok.
    • By Mister907
