By davefrombc
What do you use for communications to home or for an emergency when out of cell phone range ?
I haven't seen any threads on here concerning communications for emergency or just to keep in touch so I figured it would be interesting and helpful to get one going. We never think about it when riding , but we should .. Too many people have gotten into serious trouble while out riding and in such a case being able to call for help becomes a major consideration.
I bought a Starlink Mini and wonder if anyone here is using one or a satellite emergency communicator like the Zoleo . At the moment I have lent my Mini to my granddaughter who is working in a remote mining camp. We have run some tests using it on standby mode and got very pleasantly surprised at just how well it works without having to have it on an expensive plan. Initially set it up on their 100GB data plan but set it to drop to standby on billing date.. At a size of about 12" x 10" it can easily be carried / set up on a quad or ATV / 4x4
By joshualutz
By USRaider
Hello all!
By tin
By JBuckeyeJ
I got the old thumper going. My best guess is it sat in a barn for the past 10 years. Now that I know it runs, it’s time for a valve adjustment and tracking down a clutch cover.
