Need advice for experienced riders
By quadcrazy
Why Riders Like It
2. ITP Cryptid
Features
3. Outlaw 2 ATV Tires
Pros
4. STI Out & Back Max
Highlights
5. SuperATV Assassinator
Features
25-27 Inch Tires
Bias vs Radial Mud Tires
Bias Ply Tires
ATV Mud Tire Maintenance Tips
Final Thoughts
By Louznmemind
(Question is at the end if you want to skip my blabbering) I got this unbelievably well taken care of Grizzly 350 in for a carb clean, it belongs to an elderly couple that bought it brand new in '07. Apparently whoever has been doing their oil changes for them never checked the air filter..
Obviously it got debris in the carb, it would still run but only idle with slight choke. I've taken it apart and cleaned it, have new o rings, gaskets, etc. As far as the mixture screw is concerned, I'm assuming I obviously need to remove the plug. I'm mainly a lawn equipment guy, I've worked on slide carbs in the past but never an unmolested one with the plug still intact. I hate to mess with it as the carb had very little debris but I'm sure the o ring needs to be replaced at minimum. Finally, the question: what's the best way of removing the plug? I DO NOT want to mess up this carb..
By Louznmemind
Can someone please tell me the fill point on the drive axle? '07 Grizzly 350, straight rear drive, not independent. Thanks
By mikeexplorer
