Happy Holidays all!!!!!
I will be riding my 700 Grizzly over the holidays in Indiana. We had a few hangups last year so I want to get a good, solid winch so there will be no hang ups this year. I saw a couple of different Warn winches BUT I am not sure which type to buy, an RT or and XT. And which size do I buy. Sorry for the elementary questions, just trying to make sure that I buy the correct one. THANKS
I know next to nothing about what winches are best for which ATV's, I am a sport/race guy all the way. But I do know that Warn is the most popular name when it comes to winches, if I were to buy a winch for my Blazer, it would definately be a Warn. So I think you are on the right track there. I am sure someone with some experience in this area will chime in at some point, hopefully soon.
your names for your winches in the U.S.A is different from canada. I would assume that rt means regular usage and xt would be extreme usage. if that is the case then i would go with the xt with a 3500lb pull rating. also run winch rope instead of cable. this will eliminate the kinking and freying of the cable. as well carry a snatch block. this if ran to your anchor point with the rope and back to the quad will double the pulling power of the wich and barely work the winch as well. The last thing is WARN WINCHES are the best winches that money can buy, although the price usually sucks up a few Benjamins.
WARN is the way to go man! they cost a little more but everything FITS unlike some other brands. Go a little bigger than you think you need, also put a circuit breaker inline between the winch and the battery so you don't smoke any wiring. It can get pretty hot....
    • By quadnut20
      Why Riders Like It
      2. ITP Cryptid
      Features
      3. Outlaw 2 ATV Tires
      Pros
      4. STI Out & Back Max
      Highlights
      5. SuperATV Assassinator
      Features
      25-27 Inch Tires
      Bias vs Radial Mud Tires
      Bias Ply Tires
      ATV Mud Tire Maintenance Tips
      Final Thoughts
    • By Louznmemind
    • By Louznmemind
      Can someone please tell me the fill point on the drive axle? '07 Grizzly 350, straight rear drive, not independent. Thanks
    • By mikeexplorer
