By Brantley11
Hey everybody,
Here is where we sit:
New 93 Non Ethanol Gas
New Spark Plug
Bluish white spark
Good Compression
Here are the readings:
By DarkRider
By Sofaspud
By Am2007
Hi everyone,
owner manual
service manual
engine manual
I have the first 2 but i can not find the last one, part number 219100232. If someone can guide me where do i find the oil strainer so i can clean it i will appreciate it. im going to do an oil pressure test tomorrow to check how many PSI i have, just to make sure.
By huntindog
Also , I have a mystery bolt That I cannot remember where it goes. M6x 70 or so. Hex head with a flat washer.I will try to attach a pic.
TIA
