Similar Topics
By DarkRider
Hello there!
I'm new to the forums, but not new to the hobby. Admittedly though, I'm not super mechanically capable. But usually my contributions result in the problems I've attempted to solve via help with the forums and I will post my solutions. Or it I've solved a problem myself, I will post about it and how I solved it.
I've owned a lot of used (ever bought new) ATV's from: Yamaha, Honda, Suzuki, Kawasaki, and Polaris. From sport to 4x4, and have developed all my biased opinions of each brand.
Well that's my intro in a nutshell!
By ft4u
I actually became a member back in January but now I am a premium member. I am purchasing a 2002 Honda ATV and it needs some work. Fairly new to the ATV world. I have worked on automobiles/trucks and small engines for most of my life as a hobby. From what I have seen so far it is a very helpful community on here and excited to have joined.
By TravisM
Joined a few days ago. fixing up a 01 Bayou 220.
Finally got to spark this evening with a New Igniter, CDi box and after getting the correct key switch,with help from a member on here providing me a wiring diagram. carburetor was removed for attempted cleaning by previous owner, so im putting a new one on it, All the plastics are in good shape, but not on the machine except for the front "hood".. all the fasteners for them were MIA, so i'll probably just remove the plastics to keep them from flopping down or do a poor mans ziptie job and make it look half way decent.
any recommendations for a good cheap place to get tires for it? don't need mudding tires or anything. just need tires that will hold air.
Thanks.
By Angstromm
2005 Suzuki KingQuad 700 4X4 LT-A700X
A bundle of wires taped together shorted and melted tape. After removing tape, the wires fell apart and there was no way to determine how wires connected. This is on the left side of the ATV (see attached pic).
None of the wires run to ground. None test for volts with key on or when ATV is running.
There are 4 wires that go into 3 wires.
4 wires come in from above – yellow/green stripe, white/brown stripe, green, brown.
3 wires are below – all are yellow w/o stripes & and bundled into chase with a blue & a green wire that pass through (see attached pic). The 3 yellows appear to come from generator.
ATV only runs off battery now. There is no charge back to battery and ATV dies upon disconnecting battery (with RPMs up). All fuses are intact.
It would appear that any wire can connect to the yellow wires, so no worries there. But the extra/4th upper wire needs to be connected or bundled with one of its mates and I have no idea which goes to which.
Any help greatly appreciated.
By Mech
View File Linhai/Massimo T-Boss 550 Owners Manual
Linhai T-Boss Owners Manual
Submitter Mech Submitted 11/14/2023 Category Other Brands UTV
Similar Tagged Content
- 4 replies
- 2,882 views
- 3 replies
- 2,795 views
- 1 reply
- 1,428 views
- 2 replies
- 2,159 views
- 5 replies
- 1,905 views
Gallery Images
By blahhhh,
By cjsservices,
By Guest,
By mike83,
By Chomp,
By monkey420,
By trouble4fun,
By mike83,
By nemesis,
By Guest,
