I've cleaned the carb,air filter and this thing still is screwed up. It starts,runs and idles fine, when you give it gas it just dosent want to go(fast) I haven't changed the plug yet, never seen this happen due to a bad plug. I guess now I'm leaning twords electrical? Any ideas in the right direction are greatly appreciated.
Pipe, jets,exhaust. We were out riding was running fine then on the next ride it does this. Not many hours on the motor. Can't figure out what the hell is going on! Could the valves case a problem like this? All the sudden? It was a matter of about 20 mins!
  • 3 months later...
      Hi everyone, first and foremost, I want to thank everyone for all the help I've received. I am so glad I found this community. I also wanna apologize if I'm spamming the forum, I come up with questions as I go, I guess lol. So when I got my Recon, the air box was missing the lid, held together by zip ties, and the filter was ripped and nasty. I have since ordered a new air box assembly. It comes with everything: the box,  lid, and filter ( the insert and the foam), and all the hardware necessary. This is the first time I've seen a metal filter inside a foam filter lol. However, my question is, I have read that you have to oil these filters? Every time I read it, it was always skimmed over, and I could not remember where I had read it. Is there a certain oil needed for this? Is the filter washable and reusable? Do I just stick the filter in oil, lol? Sorry if it sounds like a dumb question. Thanks in advance, y'all!
    • By kevinohio
    • By Rick Shropshire
    • By 97kingquad
    • By Need-help-with-quads
