i have a 95 polaris xplorer 400. just replaced the throttle cable. has oil inject cable as well. whats the procedure for adjusting the cable. start at the carb and adjust till the carb is wide open or start at the throttle adjuster on the bars. it seems to run ok and starts fine but now as soon as i hit the throttle hard it bogs and then catches up. im unsure of procedure.
That sounds more like a jettin issue !! IMO
the reason it does that is because the quad is idling to low. loosen off the cable on the handlebars, then adjust the idle screw on the carb until it has a smooth idle and does not bog when you hit the throttle. Then adjust the one on the handlebars until most of the slack except for approx an 1/8th of an in of movment in and out is obtained. then try it. from there it is just fine tuning so the quad doesn't idle up when you turn sharp left or right. good luck.
Your friendly neighbourhood mechanic.
    • By Thekevinjb
      thanks
    • By Tinkeringreg
    • By Travis_Smith
    • By Mhatayas
