Similar Topics
By gatorschevy
I own a few older quads mix of kinds a couple of Yamahas, a Honda, can-am a Kawasaki, they are older quads but in good shape the question of the day is....... what's the best way to polish up the plastic?
By Yammy
Can you ride your quad on the road or cross a road if your quad is licensed and registered and you have functional signal lights and running lights?
Let me know, I'm new to this.
Thanks!
By Ajmboy
For years I've been wanting to get my rowboat back out on the reservoir here in lower NY, just never found the time and every year came and went. Its NYS watershed and NYC water supply so you have to have it registered, tagged, and cleaned before getting a spot on one of these. Now I just need to dedicate some time to get out there and fish! You end up leaving it chained to a tree and it stays out there for 3 years before renewing it again.
By kxpro8012345
Hi All,
I have a 1992 Suzuki King Quad 300. I got it in rough, picked apart condition on Facebook marketplace. The previous owner was not mechanically inclined and threw parts, and deleted parts to get this to "run". To give you an idea of what I am dealing with he put a non vacuum carb on with a separate fuel bladder mounted on the rear rack. I live in CT and things are a bit high here so I got the atv with a plow for $400. The atv came with (3) Carbs, 1 OEM, (2) petcocks 1 OEM. What I have done / found is the neutral safety switch was ate by mice (probably the original problem), fixed that, reinstalled (cleaned and put in a new needle and seat) OEM carb, the diaphragm is a little clapped out but still flexible, installed new Fuel pump, cleaned and reinstalled OEM petcock (non vacuum) has slight drip every now and again as I did not replace the tank side gasket when I installed and installed a brand new battery. doing all that the quad fires and runs but briefly. On the handle bar the choke paddle is broke off, I ordered that and looks like you need to remove the grip to install so haven't done yet and If i can get some direction on that as well, So that is "floating" in the carb as I do not have the correct choke cable connector, I took the one off the Chinese carb and it somewhat holds it in place. The air box and system are gone and it has a stubby K&N cone filter on it currently. So the way I start it is pop off the air filer, hold my hand over the carb to get a good enough vacuum to get to the bowl, then it will run for a few seconds. The tank is filled to the top, to help it out. Does anyone think I am missing anything before purchasing the entire air box system (If I can find it). This will be a yard machine for work and will not be taken out recreationally, cool little machine I would like to keep it, but unsure if I will spend the money on a airbox system as it for sure seems I am not pulling a good enough vacuum with out it.
Similar Tagged Content
- 5 replies
- 5,723 views
- 3 replies
- 7,473 views
- 2 replies
- 1,755 views
- 2 replies
- 5,708 views
- 7 replies
- 12,281 views
Gallery Images
0By SeanKing,
1
0By StolenATV,
2
1
2
4By blahhhh,
0
7
11
6By ddwyerfire,
2
5
4By mannyortiz7,
1
0
20
2By onequikkaw,
1By crazt4stroke,
1
