cant get starter to turn, replced the solinoid and all relays. i dont get any power down at the starter. i can jump the starter and it will crank. the solinoid clicks but no power comes out of the other side that go's to the starter. any suggestions :aargh:
Check all your wires and connections from the starter up. It's possible that your ignition switch or start switch is bad also.
* Edited thread title, added manufacturer and issue.
Check the low current feed wire on the solenoid for voltage when you hit the start button. If power is getting there, then the solenoid you installed is bad. If no power is getting there, then you have a problem with the start button, or the wiring into or coming out of the start button.
You could have bad contacts in the start switch. I've had to replace that before
Take a large screwdriver, and place it on the two bolts on the soleniod, it will spark some, but it should turn over the starter. If it doesnt, charge your battery, and check ALL your connections, clean everything, and make sure it is all hooked up properly. Good Luck!
    • By logray
      Hi all,
    • By oztrax
      MAX 4 6X6 2008
    • By cruteg8
      Does anyone know  the orientation of the bell crank for scrambler 400 2x4 it was not hooked up when I bought quad the way  i put it high goes into reverse and vise versa I flipped it 180 but that put  the shift rod at big angle and it just kinda grinds into gears so dnt think that is right either pretty sure it has to be the exact orientation and the rod adjusted accordingly but I cant seem to find it anyone knows please help
    • By HoldenBoy
      Hi all,
    • By crankin
