By HoldenBoy
By crankin
By cruteg8
By sunn
Temp was mid 70's, with ATV not run for maybe a month but on battery maintainer with full bat charge noted. The atv started, but then died a couple times after repeated attempts. But when run awhile everything was ok. Although when starting now I do hear the fuel pump humming but seems to take a few ,"long" seconds before full prime pressure.
I've priced a replacement fuel pump on eBay for less than $40 so am tempted to simply replace it for good PM. Just had all covers off so looks really easy to replace.
Any ideas?
By Adamb2025
