The "engine hot" warning keeps flashing even when the bike is off for several hours. i unplugged the temp sensor and had it tested. It appears to be fine. With this warning flashing the fan wants to run all the time. I have not been able to locate a wiring diagram on the net, is there a relay that could be stuck?
if your fan is running all the time then there is nothing wrong with yourwiring. back wash your rad by pulling out the fan. if than is good then check your brakes. if you have a caliper dragging then you can overheat the engine. you can also do a coolant flush. if your fuel mixture is a little lean it will cause it to overheat. if all of these are ok then i would buy a manual. if your plug gap is to wide it will do it as well. if you put to hot of plug in it will do it as well.
Appearing to be fine and being fine are two different things, electrical components may be bad even if they test ok. How long does the machine run before you get the warning light? If it comes on immediately, I would say the either the sensor is malfunctioning or you may have a short in the wiring. If the light doesn't come on until the machine has been running for a while, then you may just be running hot. Make sure you have plenty of coolant and clean oil. How does it run, do you have any performance problems?
I haven't rode the bike for 3 days. When I turned the key on the "HOT" warning starts flashing the oil was changed and the coolant level is correct. The bike runs fine even with the light flashing, the fan just runs all the time even with the key off
I work at a chemical plant. The electrical shop has a test bench where they can heat temp sensors to test them. They can check at what temp the contact opens and then where it resets.
  • 3 years later...
    • By digrig
      Hey everyone,
    • By Ironworker709
      I have Grizzly 700 that has been pretty much totaled out in a bad accident, but it will still run and drive good...
      Will this engine swap into any of the Yamaha UTV's like thr rhino and Viking 700's?
      Was just going to sell it as is for a engine for someone who needs one pretty cheap..but been thinking about getting a UTV for the family and maybe find one with a blown engine cheap and swap it out
      I already an excellent shape 2001 Big Bear 400 4x4 for us..but kinda been looking for a good used UTV for us and the grandkids on our property to play with
      Not sure of the year..i can't remember what year it was when i picked it up for a buddy a few years ago..he went to jail after he totaled this thing and told me to pick up a few things at his house he was renting and just keep them for myself since he owed me a bunch of money before the landlord sent them to the dump...
      The first picture is when i went and picked it up for him..second is how it is now..frame is all twisted up and plastics are fubarred..going to sell the rims and tires.they stick out way too wide on my Big Bear
    • By shorty
      FYI: I used a volt meter to test the stator/rotor output. Pulled the plug on the rectifier/regulator to access the 3 wires coming from the stator. The other 2 wires are 12v pos and negative so easy to identify the 3 stator wires, which are yellow on my Kowhockey. You should see around 30v AC not DC coming from the engine stator. Test all three wires to EACH OTHER not ground. Remember the stator puts out AC like an alternator. The rectifier converts the AC into DC to charge the battery. On my case the rectifier/regulator was bad, obvious because the 3 stator wires showed 30v AC
    • By jatho
      What is the best engine oil to use for the Suzuki King Quad - also any other tips and tricks I should know before doing an oil change on these bikes
    • By Maddman200
      Can anyone recommend a good quailty bottm end rebuild kit for a 09 grizzly 700. I need to replace crankshaft and bearing and do not want junk quality?
