Does anyone know about the led lights on a Gator. Mine arent working. Its an automatic so I think they might be for forward and reverse, possibly a temperature light. I dont know why there arent working. If anyone knows anything about them I would appreciate some info. Thanks
    • By Shadow soul60
      So I want to put LED headlights in my 99 Bayou 220. The stock headlights have some issue in the connector and they only work some of the time, so I want to replace them with LED light bars. I want to run them off the high beam switch. Which wire would this be?
    • By bigd764
    • By gt_jacket
      Hi,
      I have an 04 bear tracker, with a minor starting quirk. It starts in gear with brake in.  Neutral and Reverse lights work.
      All gears shift fine with no issues,  has anyone seen this before?  Just wondering if it is a bad sensor or something needs adjusting.
    • By Vlaco
      I want to replace the factory headlights with LED bulbs. Any idea a good one to get?
