my four wheeler has a cdi box with 5 pins coming out but the plug in has 6 pins that plug into it the red wire carry the votage does not plug into anything on the cdi box how does the cdi get it power if the red wire dont touch any pins
what are you working on quad info. and did you replace the cdi or whats going on with it . What are you trying to do????
i brougth a 90cc 4 wheeler a week ago that stop running i broughy a new cdi then i notice that the cdi has 5 pins and the hookup harness has 6 pins one is red that dont touch any of the 5 pin and it has the votage in the red wire so the cdi has no power to it i could not fine a 6 pin hook up
are you there hangingon
90cc used four wheeler no brand name stop runing on the person i brought it from the cdi has 5pins coming out. the wire hookup has 6 pins, the red wire carry the votage in it but does not touch any of the cdi 5 pins. they run to the other wires. how do the cdi get any power if the red wire dont plug into pins. i dont think they make a 6pin plug in on one solid plug. no spark no power to the wires that plug into the coil please help. do the red wire still put power to the cdi some way?
dont have anything on it that say what model or make or year it an off brand do you know anything abot electric or cdi box should my cdi box have 6 pin plug in like the harness that on my atv?
Without the year make and model its hard to tell :no:Usually there is something stamped on the frame or on a side cover ! If you can post a picture of it maybe someone can help you figure out what you have :yes:
    • By Adamb2025
    • By davefrombc
      Anyone  carrying  a power box when  camping with their ATV?  I built  a custom  one.  I  used a  marine  battery box that  has 2  50A Anderson Grey connector  outputs (  changed one of the greys to a red), an accessory socket  and2  USB outlets,and a battery  voltmeter ..  I  added a Pure sine wave 1,000w inverter to it and A red 120A Anderson connector to the  output  posts.. To  charge the  100Ah LiFePO4 battery  I  put in the box, I added  a DC to DC charge adapter that I  made input connectors for to allow charging the battery from a vehicle's  accessory socket  or a solar panel.
      It  was a fun  project.. Besides  having a  1,000w power box for  120V ac , USB   and  12v accessories using the 10 A socket.  I  have  50  A  Anderson connectors  and the 120 A connector  to run  things like a  12v electric outboard   for fishing  trips .  The LiFePO4  battery  only allows a max output of 100A  so  it  can't be used for something like jump starting,  but  it  is half the weight and  delivers twice the capacity of a lead acid battery running accessories..  Commercial pow2er  boxes  don't  deliver  high draw 12v output to run things like  the  electric outboards.   That's one reason  I  custom  built  mine.   One box that serves for both camping and fishing.
    • By dkgg5755
      Im not getting 12v to ignition switch with key off or on I've jumped brown wire from starter relay to positive and neutral light comes on and push button start works. Can't figure out where to go from here any help appreciated l.
    • By Need-help-with-quads
    • By Shadowace
      I have a 2016 artic cat 700 tbx seems like the power steering is not working what some obvious things that I can check.tks.in advance.
