just replaced the piston and bored the cylinder, now putting back together.....the headpipe is only held on with 4 springs, and frankly, the connection is a little loose (can be moved when pulled on, but not completely off). Aside of buying a new one, has anyone got any suggestions to make the fit tighter? (like putting something in both ends to re-fit it?) If not, I guess I go get a new one......*sigh* and YES, I replaced the springs. (and just about everything else on this thing) Thanks!!
I would love to know how that thing got so beat. I have mine for 6yrs and we all know how I ride it. the only repairs I have done have been from wear and tear I caused. Hopefully you can get this thing straightened out and enjoy it.
    • By mikeexplorer
    • By kevinohio
    • By Atomusthenes
    • By gatorschevy
      04 Suzuki Quad runner 400
      86 Kawasaki bayou 185
      96 Polaris magnum 425
      95 Polaris trail blazer 250
      03 bombardier 175 rally
      92 Yamaha moto 4 350
    • By Joeguy
      So i bought a chinese carb and in messing around still trying to get it to run right i figured id pull the spark plug to see if it was running rich, well it was definitely but also i have a nasty mark on the strap (i think thats what its called) that looks like the piston has been smacking it. I never actually pulled the plug because i had it running for a second on starter fluid when i first bought it and was just stupid and figured whatever was in there was good. The part number on it is DPR7EA, which is similar to what is called out for in the manual but i assume the little bit off that the code is means it must be a bit longer or something. Unless the plugs are made like this, but i can pretty easily see that metal has been pushed away from the area of impact. What are the odds that my piston is trashed now you think? It does still run just not well due to carb issues but thats a whole other problem.
      Actually i just took a second to google both plugs and it says the reach is the same its just different resistor values and gap size, so maybe the bigger gap is why its hitting. Either way the actual one for it is on the way and i hope it just didnt do to much damage. Wish i woulda just went over the whole thing like i normally do with this stuff.
