Okay here is my issue I have just bought a quarunner and it startsup just fine but then idles high, I have adjusted it were is sounds about right, now the othr problem is that it back fires when I go about 20-30 mphs it want go much faster the carbs were just replaced so I have no clue what else I can do
The choke has been off, and the carbs were just rebulit but they could have had missed something, I took it to the shop I was just running out of ideas they seem to think it might be a bad valve, but he is goiing to run some test first,
Have him check for vacuum leaks also !! Could be valves need ajustment also !!
    • By Jdeaton011989
    • By gordonmacritchie
      all fuses are fine
    • By digrig
      Hey everyone,
    • By ButchM
    • By dkgg5755
