Was there a little grove with a cir-clip on the axle you removed? If that is the case I usually push the axle all the way in then give it a good yank out. You have to compress the clip to free the axle.
I know with the Arctic Cats if you get one side out you can see the other axle and use a punch and tap the opposite axle out.
Anyone know how to get the front axle out of the front diff 03 kawasaki prairie 650 one side just pulled out the other side being the left I can not get out.
Have your tried a hack saw !!:laugh:
It's not to bad at all It's the things like getting the exhuast to slip off from the front pipe I had a problem getting 1 front axle too pull out of the diff. On my old quad the axles came out with no trouble today. It's just alot of parts and you have to remember I pulled stuff off that doesn't need to come off if I didn't want to paint the frame. I'm pulling everything off my old quad for the extra parts since the frame is no good.
  • 6 years later...
    • By noticon75
    • By oztrax
      MAX 4 6X6 2008
    • By toe420
