Welcome to the Forum.
4X4 400 is fine. You might have to keep up with the snow when it is going to snow alot. I plowed with a 2X4 and as long as I was out there every 4-6" I was fine. With 4X4 you will have more of an advantage. If you are having a hard time you can always do some clutch work.
    • By Brent Wright
    • By Westfalia
      So I've been told that it is a waste of time to use the two piece rims with O-rings like they came originally and to just use tubes.  I have not had much luck finding the 5" O-rings anyway, so how do I go about sizing tubes for these rims? I think they are 7 or 8" wide.
    • By mga
      My 2000 big bear 400 4x4 has 26x10x12 tires in front and 26x12x12 in the rears. Trying to find replacement tires those sizes are hard to find, or, when i do, they cost a lot more than i want to spend.
      But, there's a lot of 25" tires out there the same size, just 25" and not 26". If i got the 25" it should not make a difference....right?
    • By p5200
      Can someone please tell me what size socket I need to remove the valve cover? Thanks! 🙂
    • By DaveCargill68
      Looking to get my kids started, eldest is 8 and youngest 4, think it makes sense to hook them up with ATVs already? Or wait a few more years
