hi: i have a 01 kawasaki bayou 300 4x4 atv., that a leaking fuel fiting, i have repaired the shut-off valve, by installing a repair kit, in it. but it is still leaking fuel, around the fuel outlet fitting,. i have also replaced the o-rings, don't known how many it takes. on the fitting. there must a clip or clamp, or some type of retainer or something that holds this outlet fitting in place. please help me. thanks.
hi: no where it gos into the fuel shut-off valve, i use the worm-gear type clamps, on all the fuel hose connections. this fuel line fitting, connector, is made of aluminium,. and fits or pushes back into the fuel shut-off valve,. and then you push your fuel hose, onto it. and then slip a clamp, onto the hose,. the problem that i am having right now. is when you push the fuel fitting connector, into the fuel shut-off valve, it will not hold in place in the fuel shut-off valve., that is where the fuel is leaking. thanks
Drain the fuel, clean the connection and apply a slight amount of RTV Silicone to the fitting, then clamp it with a real hose clamp. Make sure you let it dry and be careful not to get any inside the fuel line. Drying time should be a day+, then add fuel.
If that does not work replace the fuel hose it may be stretched.
hi: fuel, is not leaking around the clamps, i am useing good quality fuel hose clamps., thats not the problem. the problem is fuel is leaking around the fuel line fiting, that fits inside the fuel shut-off valve,. this elbow type fiting has an o-ring, on the shaft of it. and is made of aluminum metal,. thanks.
* Merged this post into this thread. Please reply within this thread rather than starting a new thread on the same issue. Thanks!
Fuel vale body to inlet tube leakage is usually a bad vale assy. I've fixed mine empty or tilt tank a good cleaning of both the body inlet and fitting spray with brake cleaner and epoxy it back in place being care full of getting any epoxy inside clamp it in lightly, wait at least 48 hours before putting in fuel. beware it's not ,necessarily a safe way to go but it will hold until you get a new assy. I've had mine last for years but i wouldn't sell it that way.
Edited by racers
    • By jay41198
    • By marlon smith
    • By quadnut20
      What does everybody carry to fix tires on trails ? Looking for suggestions on Kits to buy !!
    • By LCP92
    • By oxidized_black
      1985 - 1990 Suzuki LT230 & LT250 service manual
      https://www.quadcrazy.com/files/file/532-1985-90-suzuki-quadrunner-lt230-service-manual/
      1987 - 1998 Suzuki Quad Runner 250 & King Quad 280 service manual
      https://www.quadcrazy.com/files/file/268-quad-runner-250-king-quad-1987-1998-service-manual/
      1987 - 2006 Suzuki LT80 service manual
      https://www.quadcrazy.com/files/file/89-1987-2006-suzuki-lt80-service-manual/
      1987 Suzuki LT500R Quadzilla service manual
      1988 - 1992 Suzuki LT250R Porting Instruction
      https://www.quadcrazy.com/files/file/90-1988-1992-suzuki-lt250r-porting-instructions-manual/
      1988 - 1992 Suzuki LT250R Quadracer service manual
      https://www.quadcrazy.com/files/file/91-1988-1992-suzuki-lt250r-quadracer-service-manual/
      1988 - 1992 Suzuki LT250R Tuning Guide Instruction
      https://www.quadcrazy.com/files/file/92-1988-1992-suzuki-lt250r-tuning-guide-instructions/
      1999 - 2004 Suzuki King Quad 300 service manual
      2002 - 2007 Suzuki 500LTA service manual
      2002 - 2009 Suzuki LTF250 Ozark service manual
      https://www.quadcrazy.com/files/file/94-2002-2009-suzuki-ltf250-ozark-service-manual/
      2003 Suzuki LTZ400 service manual
      2006 Suzuki 50LTZ Quad Sport service manual
      2004 Suzuki 250LTZ Quad Sport service manual
      2005 Suzuki LTA700 King Quad service manual
      2007 Suzuki 90LTZ Quad Sport service manual
      https://www.quadcrazy.com/files/file/97-2007-suzuki-90ltz-quadsport-service-manualpdf/
      2008 Suzuki 400FLTF King Quad service manual
      https://www.quadcrazy.com/files/file/98-2008-suzuki-400fltf-kingquad-service-manual/
      2008 Suzuki 750 King Quad service manual
      https://www.quadcrazy.com/files/file/99-2008-suzuki-750-kingquad-service-manual/
      2009 Suzuki 400LTZ Quad Sport service manual
      https://www.quadcrazy.com/files/file/100-2009-suzuki-400ltz-quadsport-service-manual/
      ALSO CHECK SUZUKI ATV SERVICE MANUAL DOWNLOADS
      Please visit the downloads section for ATV manuals at https://www.quadcrazy.com/files/
      Also available at:
