2006 Polaris Sportsman 500 X2 efi speedo quit working?
CK1999_400ex
Too me it sound like the computer has a problem. If the odometer is working but the speedometer isn't then there is a short in the computer or broken spot on the display board that is stopping it from displaying speed.
Not related to the speedo but to explain the broken board. I had a CB in my van I had and the transmit worked till it got warmed up. Took it to the shop and they found a small crack in the connection. Made contact cold but after electric flow through it some and it got warm it lost connection.
    • By mga
    • By McG75
    • By Clydaho
      Any other ideas?
      Thanks for any help,
      Clyde
    • By DrtyGrlKristin
