New guy here from NY.
Not a quad owner YET. Want to learn about them and get one relatively soon, if possible.
I'm 21 and live in Central NY, where snow is a BIG problem. Which is why I picked the name "plower" :)
Thanks for having me.
Thanks. I just ride, no racing. We have a house and plenty of land. It used to be a farm and a huge field. Now the field is smaller with a development behind the tree line. Sucks.
    • By prdicon
      Polaris it a bit cheaper.
      Let's say 3-5 years from now.
    • By cruteg8
    • By ButchM
