My movie debut
By rjsummer
By middlebrookgt
By mikeexplorer
By roggers
Hi everyone,
I often work on both ATVs and larger construction equipment, and I’m always on the hunt for solid OEM manuals—service, repair, and parts. The usual searches give a lot of random PDFs or unofficial scans that aren’t very trustworthy.
What online sources do you all use when you need a factory manual quickly? Are there sites you’ve found that consistently provide genuine OEM content for ATVs or heavy machinery?
I recently came across Heavy Equipment Manual, which claims to provide verified OEM service and parts manuals (covering brands like Caterpillar, Komatsu, Kubota, etc.). Has anyone here tried it, or do you have other go-to resources you’d recommend?
I’m interested in options that are:
· Fast to download
· Cover both heavy equipment and ATV models
· Clear on licensing and safety
Thanks for sharing your experiences and any recommendations!
By DayBreakJim
20230725_171507.mp4
