By BillR94
By BuckBilly
Just thought I would start a poll on this topic manly because I'm not a fan of belt drives. Just want to know which you prefer.
By middlebrookgt
By C2INS
Does anyone know if they're interchangeable? I have a 2002 TRX20TE and 2007 TRX250TE, so getting to a set of common engine parts would be ideal.
