Well, hello to everyone at quad crazy....... I am back w/another question about my 350 raptor. So i changed the entire electrical system w/a good wiring harness and the the quad i got parts from ran not 20 min before i took parts off f it. So i get it back together and try to start it and still no fire. So i took the side case cover off again changed the stator and tried it it started... Yea!!!!!! Well, thats what i thought til i torqued the bolts on side case and tried it again and what??????????? No fire again...... So tell me what it could be cause i am lost and dont know what else to do? So once again Spangie1076 needs anyone or someones help..... All suggestions will be considered cause i have the slighest idea of what to do
    • By HHurks
      Thank you!
    • By Dutchaaron
    • By Eisenmatt17803
      Good Morning!
      Thanks in advance.
