By luckyyyyesther
Hey all!
By p5200
20240217_114429.mp4 -
By p5200
By p5200
Hello folks, I have a Polaris 500 Scrambler. Not positive I need a new battery. The folks I got the ride from said they put a new battery on it right before selling it to me. It's been a couple cold months before I tried starting it. After jumping it now, I let it idle plus revved it quite a bit for about 20 minutes. Then I shut it off and tried to restart barely turns over and that's it? Am I not giving it enough charge time maybe need to actually ride it? The battery on it is a Continental CTX9-BX. I lf a new battery is needed would maybe Amazon have a decent one? Thanks!
By GTX-Racer
I am looking for a front battery cover for a Suzuki Quadrunner 250 (year unknown). It has the headlight on the handle bars and no speedometer.
