:skeptic: ok guys i am runnnin into problems with my ex the splines on the axle are wearing out and i cant keep the hubs tight anymore they just keep getting looser.... im tryin to get some advantages here so i heard the 250r is interchangeble with the ex is this tru?? and if so is the axle and hubs combined gonna be shorter or longer cause i dont want it shorter..... need to know any advantages and disadvantages of this change...
Help is apreciated:yes:
Why wont you put in another 400 axle? From what ive read the splines are different on the hub areas. Most 250r riders seemed to be putting 400ex axles on their bikes.
Sent from my SGH-T959V using Xparent Blue Tapatalk
Edited by marioweldinginc
i thought bout puttin a 250 axle in because i can get it cheaper and im kinda low on funds right now..... if i can find a cheaper 400 axle i will get it
    • By Jason39
    • By austinfuller22
      i have a lt 230 and the e start isnt working but i dont know why
      can i have some help
    • By Tim Keiper
    • By robert63
      my cat only has 100miles on it and is in mint cond. since i bought it new in 2009 it has had what i believe to b a carb problem. going down a steep hill makes it want to stall. as soon as u r on level ground its fine.and at top speed it kinda acts like its starving for gas. u let off the throtel a bit n its fine. idels good starts good. hav taken it back to dealer several times. they eithor said it didnt do it or mayb bad gas. my friend says it sounds like the float level isnt rite. any advise would realy help.
