Badley warped, bent and marked up rear rotor.
My 1987 Warrior's rotor is about an inch larger then the ones readily available.:aargh:
Is there an easy way of moving the caliper in to fix the problem.:yes:
Any body make the larger rotor at about 9-5/8" outside diameter for Yamaha Warriors.:no:
The rotor offered by EBC and Yamaha is 1" smaller then the one on my Quad.
Discontinued Item Need larger Rotar as per original (9-5/8" outside diameter) or mover caliper in.
Has any body dealt with this issue?
My ATV is at my cottage 200 miles north.
A friend & I took off the rotor without really looking at the mounting of the caliper.
I assumed Yamaha had the replacement parts.
EBC said they started making rotors in 1988 and only make one size.
