with the machine in super low range, it could probably turn a set of sherman tank steel tracks. but it would not do it for long. nothing in the drive train is designed for that! i do not know what kind of problems you would run into running rubber tracks on one. i understand the idea, but unless you are trying to use it under extreme conditions.i am not sure it would be worth all the cost and trouble. if you decide to go for it, i wish you all the best.
    • By Adamb2025
    • By superdude811
      Can you put tracks on manual atvs? would it be effective? is 280cc enough to even move them? thoughts/suggestions?
    • By davefrombc
      Anyone  carrying  a power box when  camping with their ATV?  I built  a custom  one.  I  used a  marine  battery box that  has 2  50A Anderson Grey connector  outputs (  changed one of the greys to a red), an accessory socket  and2  USB outlets,and a battery  voltmeter ..  I  added a Pure sine wave 1,000w inverter to it and A red 120A Anderson connector to the  output  posts.. To  charge the  100Ah LiFePO4 battery  I  put in the box, I added  a DC to DC charge adapter that I  made input connectors for to allow charging the battery from a vehicle's  accessory socket  or a solar panel.
      It  was a fun  project.. Besides  having a  1,000w power box for  120V ac , USB   and  12v accessories using the 10 A socket.  I  have  50  A  Anderson connectors  and the 120 A connector  to run  things like a  12v electric outboard   for fishing  trips .  The LiFePO4  battery  only allows a max output of 100A  so  it  can't be used for something like jump starting,  but  it  is half the weight and  delivers twice the capacity of a lead acid battery running accessories..  Commercial pow2er  boxes  don't  deliver  high draw 12v output to run things like  the  electric outboards.   That's one reason  I  custom  built  mine.   One box that serves for both camping and fishing.
    • By dkgg5755
      Im not getting 12v to ignition switch with key off or on I've jumped brown wire from starter relay to positive and neutral light comes on and push button start works. Can't figure out where to go from here any help appreciated l.
    • By Need-help-with-quads
