im still trying to get my chain on my raptor. i ve been trying to get the master link on my chain the last couple days . i got it shortened to the right length and got the out side plate to snap on . no i m just trying to get the snap ring on. the first one broke in half. the second one snaped off and flew across my shed somewhere. and i had one more and got it ,sat down to put on and it MIA . have no idea where it went to. i m going to pull my hair out soon. i got all my other parts on but that. i just want to get it done so i can ride. :aargh:
Masterlinks can be a bi*** at times !!:yes:Ive had good luck lately !!
i feel sory for ya man:frown:..... i had the exact same problem with my 400ex wen it was time to put a chain on it...:yes:
Well i finally got it on. went out and it took a whole 5 minutes. the snap ring went right on no problem at all. i don t understand how i could struggle so much one time and the next its easy as that. going to go for a test ride after work today. so hopefully everything holds together. And also 2 seconds after i got the new snap ring on i bought i found the one that went MIA on me. thats how it works sometimes i guess.
:partyc::cheers2c:i would also like to thank everyone for all of your support though my difficult time. LOL
your next post better be of your finally riding !! with pics !!!LOL :huh:
:huh:
    • By Yamahahahaha
    • By Gtc4d
      Thanks.
      Todd
    • By BillR94
      Thank you for your time
      Bill
    • By jordan_ATV
