My sons kazuma 70 has been loosing power and doesn't want to pull up a hill. I'm thinking. It's the clutch but I'm no expert. I tried to adjust the clutch but the stud seems to spin freely and doesn't tighten up in the counter clockwise position. Am I on the right track or am I looking at something totally different. Please help
    • By quadnut20
    • By Adamb2025
    • By sunn
      The clutch engagement on my 2021 cforce 400s was approx 2700 RPM, very abrupt/not smooth.   I obtained a "kit" from RNG consisting of a blue painted spring (spring force unknown) with 12 gram weights, as measured on my postal scale.  Installation was easy; 18 mm and 30 mm (not 32 mm as seen on other writings) impact sockets for clutch housing removal.  The resultant clutch engagement was still up to approx 2500 and very abupt/not smooth.
      The RNG spring was slightly longer than the stock spring, but felt slightly easier at initial downward force but had more resistance than stock as I continued to push down.  RNG would not tell me what the spring force was.
      I am really struggling to get any answers on the best combination of spring / weights to achieve a smooth engagement of maybe 1800 RPM.  Note; idle RPM is approx. 1600.
      I have searched all the forums and cannot find good information, and RNG appears to be not willing to share information.  What gives here?  Anyone with experience to share?
    • By Coyote251
    • By davefrombc
      Anyone  carrying  a power box when  camping with their ATV?  I built  a custom  one.  I  used a  marine  battery box that  has 2  50A Anderson Grey connector  outputs (  changed one of the greys to a red), an accessory socket  and2  USB outlets,and a battery  voltmeter ..  I  added a Pure sine wave 1,000w inverter to it and A red 120A Anderson connector to the  output  posts.. To  charge the  100Ah LiFePO4 battery  I  put in the box, I added  a DC to DC charge adapter that I  made input connectors for to allow charging the battery from a vehicle's  accessory socket  or a solar panel.
      It  was a fun  project.. Besides  having a  1,000w power box for  120V ac , USB   and  12v accessories using the 10 A socket.  I  have  50  A  Anderson connectors  and the 120 A connector  to run  things like a  12v electric outboard   for fishing  trips .  The LiFePO4  battery  only allows a max output of 100A  so  it  can't be used for something like jump starting,  but  it  is half the weight and  delivers twice the capacity of a lead acid battery running accessories..  Commercial pow2er  boxes  don't  deliver  high draw 12v output to run things like  the  electric outboards.   That's one reason  I  custom  built  mine.   One box that serves for both camping and fishing.
