My quad will not run with the airbox hooked up Will not go past quarter throttle as soon as you unhook the tube at the back of the carburetor it runs great does anybody have any ideas what it could be I have a bad fuel pump one on the way can that cause the quad to run like that
Airbox is getting oil in it from crankcase vent, the engine has 2 cups of oil when I drain it. I drained it out put it back in the reservoir, prime it start it up after a few minutes it starts spitting oil out?
so i have bought a quad (1985 suzuki LT250E) and the quad had the wrong spark plug and was not tight enough I now have dirty tread and a compression leak what would be my best option try to force the spark plug or take a tap and clean the tread ?
