By sandman001
By kevinohio
By Rockbottom
anybody have a electrical drawing
cant figure out problem
new starter relay, when i turn the key on all 3 leads to relay are hot red, blue, blue white. Is that correct. nothing happens ir clicks at the starter relay when i push the start button
on the relay closest to the cdi and nearest the brake light the relay vibrates as if it is opening and closing rapidly
the batter is new and good
if i short the B and M lugs on the starter relay the engines turns over but does not start and there is no spark
I ordered a new cdi but the one on the machine is only a few months old but a aftermarket
anybody have a electrical drawing or advice ir know what that relay symptom is and what activates it
By Joeguy
By Bxcall1
My 2005 TRV 500 quit on me today. No power to start, no 4x4 shift, no winch, no dash light, but the headlight go on. I’ve checked the fuse marked “main” which was ok.
There are 2 relays and 2 diodes in the fuse box. Could one of those cause my problem?
