Hi.
The air cleaner case has 2 ducts coming from or into it one goes to the carb.
The other duct on mine is not connected to anything other than where it comes out of the case. It has an open end about 1 1/2" dia ending under the gas tank with a crankcase breather connected to it.
Where should it connect to ??? (cannot see it in the service or owners manual) nor can I see any suitable connection point.
    • By oztrax
      MAX 4 6X6 2008
    • By hurnyak
      What is the best way to remove the carb on a 2000 quadmaster 500? Does the gas tank need to come off first?
    • By dkgg5755
    • By Louznmemind
      (Question is at the end if you want to skip my blabbering) I got this unbelievably well taken care of Grizzly 350 in for a carb clean, it belongs to an elderly couple that bought it brand new in '07. Apparently whoever has been doing their oil changes for them never checked the air filter..
      Obviously it got debris in the carb, it would still run but only idle with slight choke. I've taken it apart and cleaned it, have new o rings, gaskets, etc. As far as the mixture screw is concerned, I'm assuming I obviously need to remove the plug. I'm mainly a lawn equipment guy, I've worked on slide carbs in the past but never an unmolested one with the plug still intact. I hate to mess with it as the carb had very little debris but I'm sure the o ring needs to be replaced at minimum. Finally, the question: what's the best way of removing the plug? I DO NOT want to mess up this carb..
    • By ResQ91
      Hi Guys!
      Or ??
      Dave
