Thanks everyone for the effort, an if you can keep an eye out for me that would be great. Tried charging the battery but didnt have any luck with the car charger....too many Amps. Gonna replace the battery and hope for the best.
Anything I should look at also....this ATV has been sitting on the side of my brothers house for about 5 years, any suggestions would be greatly apreciated!
if you wernt so far away from me i would trade you for a running and riding quad several years newer ...
ck how do you drain the gas tank on 650 like you have I have some bad gas. Raybob
i use a boat pump on alot of atv gas tanks ... you can also take off the fuel line going to the carbs .. but dont let the electric fuel pump get hot and fry ... always keep at least 1/4 tank of fuel in it ... if you remove the fuel line from the carbs keep pouring gas in the tank till it looks like clean fresh fuel comming out the line ...
Create an account
Register a new account
Sign in
Sign In Now
    • By DaveswMN
      Thanks for any thoughts.
      For ATV and UTV enthusiasts, regular maintenance is key to ensuring the longevity and performance of your vehicle. One of the most overlooked yet essential components is the battery. Just like in cars, ATVs and UTVs require a reliable power source to start the engine and power additional features like lights, winches, and electronic accessories. Understanding why changing your ATV and UTV battery at the right time is essential—and why Weize batteries are a top choice—can keep you out on the trails longer and reduce the risk of unexpected battery failures.
      Why Changing Your ATV/UTV battery is Crucial
      1. Prevent Unexpected Breakdowns
      Imagine being out in the wilderness, far from help, and suddenly your ATV won’t start. A reliable battery ensures that your vehicle can always start up, keeping you safe and ready for any situation. Old or degraded batteries lose their capacity to hold a charge, increasing the likelihood of sudden, inconvenient breakdowns.
      2. Improve Overall Performance
      A fresh battery doesn’t just guarantee startup; it also supports optimal performance. ATV and UTV batteries power important accessories, such as headlights, which are crucial for visibility in low-light conditions. A weak battery can dim your lights, affect the functioning of electric winches, and even disrupt GPS or other electronic equipment. A new, high-quality battery helps maintain the consistent power output necessary for these essential features.
      3. Extend the Life of Other Components
      An aging battery can strain other vehicle components. As the battery weakens, it requires more effort from the alternator and other electrical parts to maintain a charge. This added stress can wear down the electrical system over time. Replacing the battery on schedule can help to reduce strain on the alternator and prevent more costly repairs down the line.
      4. Adapt to Changing Seasons
      Temperature fluctuations can significantly impact battery life. Colder temperatures reduce battery efficiency, which can lead to issues during winter months, while extreme heat can cause rapid battery degradation. Changing your battery seasonally or before long periods of extreme weather can help avoid seasonal breakdowns and extend battery life.
      Why Choose Weize batteries for Your ATV or UTV?
      When it comes to replacement batteries, Weize is a top choice among ATV and UTV enthusiasts. Here’s why Weize batteries are particularly suitable for powering these rugged vehicles:
      1. Exceptional Durability
      Weize batteries are designed to withstand tough conditions, including off-road terrain, shock, and vibration. Whether you’re tackling rocky trails, mud, or hills, Weize batteries are built to last. Their rugged construction helps to ensure reliable performance even under the most challenging conditions.
      2. Long-Lasting Power
      Weize batteries use high-quality materials that allow for a stable charge and dependable discharge rate. This long-lasting power translates into fewer replacements, saving you money over the long run. Weize batteries are built to provide reliable starting power and can handle additional loads from accessories, ensuring that your ATV or UTV gets all the energy it needs.
      3. Low Maintenance and Easy Installation
      Weize batteries are designed with a focus on low maintenance and easy installation. Many models come pre-charged and sealed, meaning they’re ready to use right out of the box. This ease of installation makes them an ideal choice for riders who prefer a straightforward setup with minimal hassle.
      4. Affordability and Value
      Weize offers high-quality batteries at competitive prices, making them a great value for ATV and UTV owners. Despite their affordability, they don’t compromise on durability or performance, providing excellent quality without the premium price tag.
      5. Environmentally Responsible
      Weize prioritizes sustainable manufacturing practices, ensuring that their batteries meet environmental standards. This focus on eco-friendly production is a plus for ATV and UTV riders who want to reduce their impact on the environment while still enjoying high-quality equipment.
      Signs It’s Time to Change Your battery
      To maximize your ATV or UTV’s performance, be aware of the signs indicating that a battery replacement is necessary:
      Slow Engine Crank: If your engine takes longer than usual to start, it may be due to a weakening battery. Dim Lights: Dimming headlights are often a clear sign that your battery is losing its capacity to hold a charge. Frequent Recharging: If you find yourself recharging the battery frequently, it might be time for a new one. Age of the Battery: Most ATV and UTV batteries last between two to four years. Regular replacements can prevent unexpected breakdowns. Final Thoughts
      Changing your ATV or UTV battery when it shows signs of wear is essential for reliable performance and safety on every ride. Choosing a dependable brand like Weize ensures that you’re investing in long-lasting power, durability, and value. With a new Weize battery, your ATV or UTV will be ready for every adventure—whether you’re out on the trail or tackling heavy-duty tasks. So before you embark on your next journey, make sure your battery is up to the challenge, and consider Weize as a trusted choice for dependable power.
    • By flyinbrian365
      The files it too large to upload so here's a link to my dropbox.
      https://www.dropbox.com/s/boeo3kewqeuj7td/2016-20 SXS Pioneer 1000M3-M3P-M3LE-M5P-M5D-M5LE service manual.pdf?dl=0
      https://www.dropbox.com/s/z6kjj2to6yyneip/2015 SXS 500M2 Pionneer service manual.pdf?dl=0
      Hope this helps someone!!
      My 2004 Yamaha Grizzly 660 is still going strong but the battery has not been holding a charge. I replaced it a few years back and have been jumping it lately but after sitting for a few days, it drains out. I recently purchased two car batteries from Weize directly because it was a good price for an AGM. I looked on weize for a YTX20HL-BS and its an AGM at $59.99. I believe they have a promo code you can find. Found it cheaper on Amazon and intalled it yesterday.
      I ended up buying the same one on Amazon which is $49.99 with a $20% coupon bringing it down to $39.99, which is a pretty good price for an ATV AGM battery.
      Just a heads up if anyone needs a new ATV/UTV battery going into winter.
      YTX20HL-BS fits a a good amount of models.
      Arctic Cat:
      Arctic Cat Alterra Arctic Cat ATV 450 Arctic Cat Alterra TRV Arctic Cat Alterra CORE Arctic Cat Alterra XC450 BRP (CAN-AM):
      BRP (CAN-AM) Outlander BRP (CAN-AM) Outlander 660 EFI BRP (CAN-AM) Renegade CF Moto:
      CF Moto Cforce 500 Honda:
      Honda TRX680FA Four Trax Rincon Kymco:
      Kymco Maxxer 450 Kymco MXU 450 Kymco MXU 500 Kymco MXU 700 Polaris:
      Polaris Sportsman Polaris Sportsman Touring Polaris Sportsman XP Polaris Sportsman X2 Yamaha:
      Yamaha Kodiak 700 Yamaha Kodiak 700 EPS Yamaha YFM40FB Big Bear Yamaha YFM40FW Kodiak/Automatic Yamaha YFM40FWN Big Bear Yamaha YFM450FA Yamaha YFM45FA Kodiak Yamaha YFM45FG Grizzly Yamaha YFM45FX Wolverine Yamaha YFM45KD KP Kodiak Yamaha YFM600FW FH Grizzly Yamaha YFM660FP FR FH FL Grizzly Yamaha YFM66FA FG Grizzly Yamaha YFM700DE DH PE PFPH PS Grizzly Yamaha YFM700GD GP Grizzly Yamaha YFM7FG Grizzly Yamaha YFV600FW Grizzly Yamaha YMF5FG Yamaha YFM550PE DE DH Grizzly UTVs:
      Arctic Cat Prowler 500 BRP (CAN-AM) Maverick BRP (CAN-AM) Traxter DPS BRP (CAN-AM) Traxter Base BRP (CAN-AM) Traxter STD BRP (CAN-AM) Traxter BRP (CAN-AM) Defender Kawasaki KAF620 Mule 3000 Kawasaki KAF620 Mule 3010 Kawasaki KAF620 Mule 3020 Kawasaki KAF620 Mule 3010 4x4 Kawasaki KAF620 Mule 4010 4x4 (CN) Kawasaki Teryx All Models (CN) Kymco UXV450 Kymco UXV500 Kymco UXV700 Polaris RZR Polaris RZR 4 Polaris RZR S 800 Suzuki 2005 QUV620F
    • By lindzjo
      Does anyone have a service manual for Qlink 700 atv.I cant find anything on one.Please help
