    • By Fanucci
      I just inherited a 2001 550 from a friend have a friend and have no idea maintenance Pass there is no manual. It is running pretty good right now, definitely needs some attention and tlc.  What basic things should be done to get it in good working order and where can I get a manual?
    • By ruggend
      Are there any video's or tutorials on an oil change for the Tactic 750?
      Thank you.
    • By mehim
      Hi everyone.
    • By p5200
      The studs in the sprocket hub are stripped out. The hub is probably walloed out also. Probably will have to have a new sprocket hub. I doubt I have the ability nor the tools needed for this job. Thanks for all suggestions/opinions!
      20240225_155255.mp4   20240225_155255.mp4 20240225_155255.mp4 20240225_155255.mp4
    • By That229Yamaha
      Hey guys, I’m new to the forum. What I got is a 2001 Yamaha Bear Tracker 250, got it as a project on trade and the problem I’m dealing with is a “no spark” problem and been trying to hunt down the cause for two weeks. I’ve replaced the stator, pick up coil, CDI, wiring harness, ignition, coil pack, spark plug, solenoid, battery, etc. and I’m still not getting any luck. Even tried bypassing the kill switch. I also noticed two things on this quad, another CDI under the back plastic by the voltage regulator, and a blue and green wire coming from the motor behind  the foot shift, tried to hook it up but it broke off and I’m thinking the broken wire would cause it to have no spark, if not then I need someone’s help on this and wanna see if I can get spark again. If anyone knows why I have this problem, the help would be greatly appreciated.
