I was going to buy a used carb that has been jetted for a certain exhaust. Since the carbs were jetted can I use them on a quad with a stock exhaust. I was planning on no airbox lid with stock exhaust until I get enough money to buy a full exhaust system.
Is this a 660 ? I would say yes u are going to have to rejet both carbs ! but I would find out if there were any mods done to the other quad ! Has anything been done to yours ?? :biggrin:
    • By marlon smith
    • By Kurt Reiser
      My quad will not run with the airbox hooked up  Will not go past quarter throttle as soon as you unhook the tube at the back of the carburetor it runs great  does anybody have any ideas what it could be I have a bad fuel pump one on the way can that cause the quad to run like that
    • By goatman
      quad is a new to me freebie, pulled carb and cleaned it. got it running and idling nice but mid throttle it craps out and will go down to almost a stall, i release throttle and it just sits there idling away happy as a pig in poop. i was thinking fuel restriction then i noticed the exhaust glowing red in the sunlight. so its running lean
    • By goatman
      bottom of the tail pipe was rusted out and the little nut also ripped off when i tried to undo it.
      a 540 ml soup can is the same id as the exhaust pipe od and the soup can has ridges to make it a tight fit
      a little bit of a mickey mouse fix but it works
    • By Sonders
      Hey everyone.  2007 Sportsman 800 and the exhaust on passenger side is getting so hot it melted the bottom side of the seat.  It's not low on coolant or anything.  Any ideas what would cause the exhaust to get that hot?
