1994 Suzuki King Quad - Oil Gets Hot
pjcs92
My 2002 doesnt have an oil temp light, just a temp light. Id double check that.
Either way, sounds like its overheating. Id check the radiator for dirt &/or debris so its getting good airflow, proper coolant level & make sure the fan is working properly. If all that checks out OK you could have a stuck thermostat bad water pump or some type of blockage of coolant in the syatem. Im no expert but I havent seen just an "oil temp" light on a quad.....but I could be wrong too.
I see, I was assuming its water cooled like mine. I guess an oil temp light on an air cooled makes sense. Id make sure you are getting good air flow around the engine & that none of the cooling fins are plugged up with mud or missing. There should be a fan somewhere on the machine, Im guessing off the crank/ flywheel. Make sure the shrouding around that is clear of debris also. I have also see a plugged up exhaust pipe make air cooled engins run hot, especially if its 2-stroke.
    • By JohnnyB
      Greetings,
    • By mga
    • By NZrider
    • By Slitzer
      How often do you change oil in front/rear diffrentials and gearbox?
    • By jatho
