    • By en4cer
      Problem number 1,
      Problem number 2.
      Any help would be nice.
    • By davefrombc
      1996-2003 Polaris Sportsman 400, 500, and Xplorer 500 service manual
      View File Polaris Sportsman 400, 500, and Xplorer 500 service manual
      This detailed, comprehensive manual covers the Polaris Sportsman 400, 500, and Xplorer 500 4x4 from 1996-2003.
      Submitter davefrombc Submitted 05/05/2026 Category Polaris ATV
    • By en4cer
      I have a 2000 Polaris 400 xpress with a no start situation,  I have spark and fuel.  Wont start on starting fluid.
      New fuel filter and spark plug. Did run prior on full choke.  Then died and not start since. I feel dumb ,  any body have a clue???
    • By frugalsob
      Hey all, been a while since my last post and can't find anything exactly like I'm experiencing.
      I have a 1996 Polaris Xplorer 300 and have fuel consistently (based on my opinion) drip from the overflow tube attached to the bottom of the carb. When parked and the fuel petcock turned on, it does not leak. However, once its running, it drips almost 1 drop per second. But only at idle. Once rpm's increase it doesn't drip.
      I've cleaned the carb, checked the float per service manual, and the rubber needle tip doesn't appear to be worn.
      Is this dripping normal? I really dont feel it should be. Or, do I need to replace the needle despite how I feel it looks.
      Any help would be appreciated!
      Thanks!
    • By johndeerefarm
      Is there any way to mod an Outlaw 50 to increase the speed? The size is perfect just would like a little more top end speed. Thanks
