BuckBilly
Recon with aftermarket wheels
12 posts in this topic
Now heres the picture of an 07 with the swamp foxes an mags on it. 23x8x12 frt 23x10x12 rear.
Edited by BuckBilly
Share this post
Link to post
i didnt know u had a honda i thought u just had the suzuki... very nice do u have another picture?
Share this post
Link to post
I own a Suzuki and my wife has a Honda. I found that picture on another website. Just thought I would share this info , maybe another recon owner or ozark owner could use the info.
Share this post
Link to post
Now you won't want to get it dirty......
It's OK tho, you have a picture of it clean!
Share this post
Link to post
Wish it was mine.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
  • Similar Content
    • By Kyboy
      Iam looking for help seperating the rear brake drum and the cover. Any suggestions would be greatly appreciate
    • By biggreen2010
      ok it will start up an run but quits a lot till it gets warm, but has a bad miss an wont idle, I have a brand new Honda carb on it, good gas flow, new plug, but when I let the throttle go below a quarter, it backfires through carb an tail pipe:confused: so it has never had any electrical work or mechanical work done...it just started all the sudden, I'm think it may have ignition coil breaking down, or cdi box going bad...anyone had this trouble before? let me know what you did to fix it. thanks:skeptic:
    • By lulu
      neutral light does not come on when in neutral, engine will not turn over. have not found any bare wires or loose connections. not sure exactly where the neutral switch is located or how to replace it. battery is hot and reverse light works
    • By D__L
      I want to upgrade, not sure what size tires will fit and do I need wheel spacers and lift kit?
      What performance mods do I need to do for the larger tires or don't need to ?
      Like the Maxxis Vipr tires.
      Maxxis Vipr front 27x9R-14
      Maxxis Vipr Rear 27x11R-14
      What size wheel will work? offset?
      Stock 25x10-12 Rears and 25x8-12 Fronts
      Stick with 12 inch wheels and get taller tires?
      Thanks,
    • By auburnfan327
      I have a 2007 Honda Recon ES and need some new tires. The stock tire sizes are 22x10-9 and 22x7-11. I'm looking at some Carlisle AT489 tires but the closest sizes i can find are 22x10-10 and 22x7-12. Will they fit? Thanks.
