By dalton7545
By p5200
By Spritee1
polaris 2008 50 outlaw automatic: got the 50 for free. would only run with chock on, replaced the carburator with new. I can't get the unit to an idle where the machine doesn't move forward. if I do get it to idle down within a few moments it will die. got something to try?
By kawasig
By beast6228
It's been a long time since I have used a forum, I was the admin of one for quite a few years, had thousands of daily active members, with lots of crazy posts and spammers, so I salute the admins. Anyway, just waving my greasy hands, Hopefully I can help others out.
