By huntindog
TIA
By vlxerdon
Hello from southeast Georgia. Was gifted a 2000 Yamaha bear tracker with out a carb or battery and looking like it had seen better days. Was told it had sat for about three years. Explained a lot. Put a carb on and a battery in and it started right up. Surprised the heck out of me Anyhow as stated in my opening I am 78 years old with a very long motorcycle backgground but brand new to atv's. Anyone else out here from Georgia? Would like to meet up with some folks for a ride or two. Looks like a great site. Thanks for having me.
Don
By kawasig
By Banshee898
2014 Honda Rancher TRX420TM1: Unit starts right up, once it warms up it stalls and more difficult to start but once it does start it won't stay running. I have replaced the fuel assembly, IACV, O2 sensor and fuel injector. There are no active DTC codes. Disconnecting fuel line at injector and turning on key there is a steady stream of fuel. Plug looks good did not see crack in ceramic. Is there any way to test the ignition coil?
Thanks for any help.
By mkibbe
My 2014 750 king quad stalls sometimes when I touch or turn the handlebars,the problem has gotten worse,my machine has 475 miles and is only trail ridden,I have a new factory battery and i have 14.2 volts when the quad is running and 13.3 on the battery when not running,also using a multimeter there is no change in volts when turning the bars until it does stall,If I pull the 40 amp power steering fuse it will not stall.......I've been told its the ECU,Hate to buy one if thats not the problem,but its kinda leaning towards that,,,,,need some opinions.
Similar Tagged Forum Content
- 3 replies
- 2,529 views
- 10 replies
- 4,816 views
- 1 reply
- 2,164 views
