2005 Artic Cat 400 4x4 winch problems
By mkibbe
By Whiterabbit
3500lb, synthetic rope lead and everything needed to install for........................................ $89 bucks! I'm installing one on my '01 Bombardier Quest and it looks like a legit buy. If you have a RK nearby & you need a winch you might want to swing by before they disappear.
By BruceG
By BenJammin
I did a compression test on my 2005 Bombardier Traxter 650 CVT and it's 75 PSI. service manual only talks about leak down test. No specification for engine compression the manual. What does 75 PSI tell me? Thank in advance.
A little history of this machine. 640 miles. Picked it up about 2 years ago, not running. Probably the computer. Tested all circuits and confirm it was the computer. Long story short, I watched a Youtube video and fixed the computer. ATV now started and runs. BUT, it tops out 20 MPH. I cleaned the carb 3 times also using a Mikuni carb kit after the second time. Slide in carb is going up and down. Only adjustment for fuel is at 1.5 turns out. NGK Sparkplug had soot on main part but brown on the electrode. Champion sparkplug is brown. I check CVT clutches and they both appear to engage like they suppose to. Checked valve clearance it's 0.00, I can't get any feeler gauges in-between. I check timing chain I believe it's in the correct position and hasn't skipped. I removed muffler plug and drilled into muffler to try and make sure it wasn't plugged.
By rgeiser
