    • By Coyote251
      I am hooking up a speaker on the rear of bike and want to use a factory auxiliary switched plug and not have to cut into the factory wiring or add another switch. I have read a bunch of posts that say there should be an auxiliary 12V connector in the front and one in the rear. I found the one in the front when I hooked up my winch but cannot find any in the rear. I have seen some pictures showing one on the right side attached to the down tube behind the side cover, but there is nothing on my 2024. Can anyone confirm that there is a auxiliary 12V connector in the rear on the 2024 700 Xmr? If so, can you please tell me where it is (with a picture if possible)?
    • By nberga
      Hi Guys,
      We've just removed a Gates belt from a cforce 1000 touring and it looks like an egg shape and we leave it on the side for about 1 week and still didn't got like the normal oval shape, any thoughts on this? Do you think it's normal?
    • By kingkw
      I have a Harbor Freight tire changer. I could not get the tires off the rim.
    • By tds7
      Do any have any experience replacing 2001 Big Bear 400 Front Differential Input Shaft bearing and seal. Getting ready to buy one but the seal and bearing are bad. Any help would be appreciated.
    • By Coyote251
