Join Today, It's Simple and FREE!
.thumb.jpg.b6904e0de398962bdadaa9703162b38e.jpg)
1987-1999 Yamaha Big Bear 350 4x4 Troubleshooting electrical starter not working
By
ruger_america, in Yamaha ATV Forum
By stymy68
I have an unknown year Timberwolf. I have had to replace/repair some back yard wiring issues. With the wiring fixed, I compared to my other Timberwolf quads, I have found a problem. Starter is always running. I can only get it to stop by removing the positive lead from the battery.
By Wesley Floyd
Hey guys, Thanks for looking at my post. I haven't had a lot of experience with problems like this before, so I'm a little bit at a loss. The Quad was really hard to shift, (the dirty carb leaking gas making it idle high didn't help either). The only Idea I have would be is that the torsion spring is worn out, and that there is a normal parameter for how much it should move when those two arms of the shift shaft assembly spread apart. That's my thought. Maybe someone who has more knowledge then me can let me know if i'm on the right track 😀
By JacobSlabach
Theres a horse farm I work/worked at and they have a Rubicon (500cc) think its a 04. Its been having starting issues. First time it wouldnt start, the owner said it had a new battery in it (this is about a year ago I guess..). I replaced the solenoid and then the starter. the battery was dead so I jumped it and then it started fine after the battery charged. about a month later, same problem. I swapped the solenoid back out with the old one(still had it)- nothing. the owner had another battery she said was good, swapped that out and it fired up. Now, today, same problem again... owner says the starter was sluggish and then the battery went dead. Went out and jumped it again and it ran fine (its a carburated atv so its not fond of under freezing temperatures...). the stater is working cause when I got there, the battery had 7-9v on it (multimeter said it was rising and falling (with the key on)). I jumped it off our van and rode it around for say 5-10mins. when I shut it off again, battery is reading 14v with key off and 13v with it on. thats as far as I've gotten.. I asked the owner to let me know if anything else happened later on.. What I'm wondering is if its just the battery, or maybe is the regulator rectifier not working letting the battery be overcharged cause it to die? And then again, the bike could have sat with the key and headlight on overnight for all I know..
By Josh Cornelius
hey guys, new to the forum, need some help.. got a 96 big bear 350 4x4 I'm bringing back from the dead and can't get the neutral light to come on to save my life.. both neutral switches are good and registering in neutral and relay is good but still no light and no fire.. any other ideas to try?
By JacobSlabach
Got a 04 Sportsman 500 that wasnt running- owner said it needed a stater and a new battery. It ran rough (been sitting out in the weather for a while). A friend and I started by adding a new battery and it would start barely with the choke and his hand over the air-filter. I decided to install the new battery in the holder on the side. we had it on the rack because the old on was still in the bike. I tried to be nifty by turning the battery to put the terminals in an easier spot to get to, but forgot to reverse the cables too. In a sentence, I reversed the positive and negative on the battery like a dummy. When we discovered my mistake and corrected it, we turned on the bike, but the display did not light up and the key did not turn on the starter. jumping the solenoid worked the starter, so we thought the solenoid just burned up when I reversed the pos and neg... new solenoid and no difference. what have I burned up? Also, the shifter does not seem to do anything in the trans. it slides back and forth like its stripped in the trans. any help would be appreciated!!
I think the biggest issue right now is the electrical.
