Need to buy the ATV + ramp.
Need a little help fixing a no spark issue. 2002 BT with the 2 wire ignition switch. I have 4 stators and 2 CDI's and 3 coils to test. The new stator reads 218 ohm, and .2 ohm, the one that came out of it reads 50K and .2, the other is 132 and .2. All of the coils are 0.00 ohm, and there is no way to test the CDI that I know. I have also confirmed the replacement stator pins match the factory locations. I did try to test milli-volts at the coil to see if it was getting any signal from the CDI but nope. IDEAS?
