By Mikey509
Hi everyone, first and foremost, I want to thank everyone for all the help I've received. I am so glad I found this community. I also wanna apologize if I'm spamming the forum, I come up with questions as I go, I guess lol. So when I got my Recon, the air box was missing the lid, held together by zip ties, and the filter was ripped and nasty. I have since ordered a new air box assembly. It comes with everything: the box, lid, and filter ( the insert and the foam), and all the hardware necessary. This is the first time I've seen a metal filter inside a foam filter lol. However, my question is, I have read that you have to oil these filters? Every time I read it, it was always skimmed over, and I could not remember where I had read it. Is there a certain oil needed for this? Is the filter washable and reusable? Do I just stick the filter in oil, lol? Sorry if it sounds like a dumb question. Thanks in advance, y'all!
By Yamahahahaha
By kevinohio
By Rick Shropshire
I recently picked up a 2000 warrior 350 and it doesn’t have the air filter box so I was thinking about using a clamp on filter directly on the carb. Anyone know what I need to get or where I can find it? The one I ordered goes in the box and won’t fit directly on the carb.
By Gwbarm
Interesting Jumper Pack. No battery to die and works well. It is basically a string of capacitors that takes the minimun voltage that is in your battery , even though its not enough to start the machine, it is enough to fill the capacitors and boost the battery for starting. The only problem is if the battery is completely dead wont do any good, but you can charge it in 2 minutes with your car battery. Interesting idea if the capacitors hold up, time will tell.
