By DexKing
Hi my name is Dex, and i have an addic..oh wrong group.
I only started actually riding atvs in late 2019 with a friend from high school. After getting out and enjoying a night of riding and camping, i just found that i REALLY enjoy being out in the woods on a 4wheeler day or night. my main rig is a 2020 Can Am Outlander 570 and recently picked up a 2004 Honda Recon 250, and a Kawasaki Prairie 360. Both the honda and the Kawasaki are projects that started in pretty rough condition and are slowly becoming running, riding machines. As i research and rebuild, i am learning new skills along the way and enjoying every minute of it. Thanks for having me in the community, i hope to learn a bit more every day from each of you out there, while also sharing some experiences with you all as well!
By Sporpo
Have a 2018 Sportsman 850 SP with factory 26x10x14 rears and 26x8x14 fronts, and it is now time to replace them. So, is it reasonable to replace all four to now be the same size of 26x9x14? Replace with radials, of course, and at least 6 ply rated. And, can a 27" tire fit on the factory wheels? Thanks for any replys...i know this has been hashed and rehashed so many times, so thanks for all replys, and, yes, this bike has had a literal ton of cash put into it just to get it running again, and still needs some tinkering, but it will be a work bike, it is not a pleasure/recreational bike like it was intended to be... LOL
By wjmedic
right front hub again
By Gwbarm
